I have a Boiler/Water Cylinder/Central heating setup.
Drayton LP522 Timeswitch/Programmer with Drayton RTS1 Room Thermostat
So far it does the following
Turn on Central heating....Nothing Happens
Turn the thermostat up/down and you can hear it clicking. Left it at 30 degrees i.e. def on
If I turn on the water heating with the CH still on then the boiler fires up to heat the water and the radiators also heat up.
Once the water is up to temp it obviously stops the boiler but as a result stops heating the radiators.
To me it looks like either the Thermostat is not working or Timeswitch is not working. The boiler obviously works when its told and the valves all appear to be working (once there is hot water to feed the system)
Think the next step is to undo the thermostat and 'short' the on connection which should either show up the thermostat as the problem or count it out.
Any other suggestions.
