Our living room layout is quite limited by the radiator which takes up too much wall space, so I'd like to replace it with a higher/narrower radiator. I did a bit of research on the internet and worked out that our living room requires about 1416W/4832BTU of heat. I also found out that our current wide round top (double panel plus) radiator which is 520mm high/1100mm wide gives off 1348W/4600BTU.
I have a condensing boiler and I was wondering if there might be any problems replacing the above radiator with a 2000mm high/460mm wide radiator that I found on the internet which gives off 1400W/4777BTU of heat.
Any advise appreciated.
Many thanks.
Many thanks.
