Hi all,
I've been trying to work out what's going on with my heating system - lots of rapid learning, but there's no substitute for asking people who know what they're talking about...
Just bought my mum's house, haven't lived there since the 90s but roughly know the history of the CH system. Has been fine for donkeys years, apart from a new pump about ten years ago (system itself is around 20-25 years old). It's an open system, F/E tank in the loft, gas powered boiler (Ideal Concord HRS) with Honeywell 3-port motorised valve next to the hot water tank.
Recently the rads have been slow to heat up, and not consistent in their heating - different ones heat up at different times. They've all got their inlet valves open, haven't touched their outlets 'cos I don't want to affect the balancing (assuming it is balanced properly!). Anyway, my first thought is there's air in the system, so I've tried bleeding the radiators and some produce water right away, whereas others either have air hissing out followed by nothing (no water, no hissing), or just the nothing (no hissing at all). There's also plenty of noise from the pipes/boiler/pump which seems to be consistent with air in the system.
I've checked the F/E tank (it's an open system) and that has water in it to above the outlet, and the ballcock valve works perfectly - so there is water available, but it's not going in to the system.
The pump is working (it's moving when you open the bleed valve cover) so my next thought, after some reading, was the motorised valve (a three-port Honeywell 4073A). Having whipped off the cover and switched the heating controls between CH/HW, Off and HW only (there's no CH only option) I couldn't see anything moving and I couldn't feel or hear the motor. However there was a brief "bubbles" sound when the switch was thrown between CH/HW and HW only - but nothing else. Finally, the lever on the head unit moves around real easy - there's no resistance with the boiler on or off. It's almost as if the lever isn't even connected. The hot water tank heats up very nicely regardless the whole time (I mean when the boiler's on), so that's clearly getting what it needs. Since there's no CH only option I can't tell if the CH water is going to the HW system when it shouldn't.
Now, there has been some work recently - two rads removed, one of them replaced with a towel warmer and the other put back in a different location (and the underfloor plumbing modified to accommodate these changes). I imagine this may well have introduced air into the system. However this was after the "nothing coming out of the radiators" symptoms first appeared.
From what I've read, it seems as though water may be prevented from entering the system if the motorised valve is not moving, and since my one has a dimple on the cover this apparently means I can whip off the head unit without getting wet to see if the valve itself works or if that's seized. I'm going to have a look at that tonight, but wanted to see if anyone else had any ideas?
Please let me know if I've left off any useful information and I'll update accordingly!
Cheers!
Cheers!
