am having a nightmare with a flexiflue. last month i replaced the pcb as it had burnt out. got a recon one from allspares in wembley. all was ok.
got another call last week. the fan had seized & the cooling ring had come loose on the shaft. fitted a new fan.
now the weird bit. the t/c would not hold unless i bridged out the connectors on the bottom of the pcb. (therefore t/c & thermo electric valve ok. spoke to ariston today & they said aps fault. what happens is that when i switch on the electrics the fan goes up to full speed & when i open the tap it goes back to rest speed. if i swap the black & orange wires on the microswitch (diaphragm) over then it behaves correctly but pilot will not hold unless i run the tap to get hi speed fan & then move the control knob from pilot to main gas. the microswitch is working correctly & so is the aps. also i fitted another pcb today but it made no difference so i think i can rule it out.
any advice please as i am quite stressed & so is the customer.
ps i am self employed gas safe registered & prior to working for 3 years on my own spent 18 years with british gas but left when they turned engineers into rip off salesmen !
