Hi
The three way diverter valve on my Y type system appears to have stopped working.
The symptoms are:
When the system is turned on at the time switch the CH and HW both work i.e get hot. However when the thermostat is turned down the CH (rads) remain hot. The thermostat has been replaced so that's not the issue.
Running some tests yesterday:
1, Turning on the CH and HW then turning off the CH with the thermostat - The actuator didn't move the valve.
2, Turning off power to the whole system - The Valve didn't return to the Port B rest position.
3, Whatever combination of Power on/off, Time Switch on/off, Thermostat on/off etc etc the valve doesn't move at all.
So I thought I'd get a plumber to replace the valve and/or actuator but after looking at it there are isolation valves around each of the branches so I may be able to do it myself without draining the system.
My question is therefore: Can each of the branches be isolated and the valve replaced without draining the complete system? What would be the effects of the air getting into the system when the isolation valves were reopened? Could it be bled out of the system through the rads?
Attached are pictures of the pipework and valve for reference. The actuator has no pip on the top of the shroud therefore replacing just the actuator would be difficult I think? Do they do a conversion kit?
[GALLERY=media, 38931][/GALLERY]
[img] [GALLERY=media, 38932][/GALLERY]
The symptoms are:
