My old CH thermostat seems to have had it's day with at least a 5C difference between the set temp and the actual temp. I'm thinking of replacing it with a new one and have a couple of questions.
What is the best one to get? I'm thinking of fitting it myself so this is both for how well it works and how easy it is to fit ?
Will it cause any problems with the programmer/boiler ? I think they are both about 15 years old so pre-digital I would guess.
What I have at the moment is a PRT100 thermostat in the hall, in the kitchen a Potterton EP2002 programmer and a Prima F40 boiler.
On a related point, is it an urban myth that leaving your heating on a low setting 24/7 uses less gas for the same heat as compared to having it switch on/off with a timer ?
Any advice much appreciated
