- Joined
- 14 Oct 2025
- Messages
- 18
- Reaction score
- 1
- Country
Hi all,
I am not a plumber/engineer so appreciate any help.
I am wanting to change a rad valve downstairs on a pressurised combi system. I have watched several videos on the Tube but cant decide which is the best way to do it without doing a complete drain down which is time consuming.
My question is can I do this by shutting off the boiler, isolating the downstairs rad closing off both valves left and right first, releasing the pressure from the bleed valve to a slow trickle and slowly letting the rad drain from the valve nut off the rad to a workable flow and then swap the valve to a thermostat without panic???
I have watched several ways, one being to isolate the rad in question and bleed off, then bleed another rad to drop the pressure?
Also another said to close off all upstairs valves and lock shields to prevent a backflow?
Another said to fully drain off so it's a mixed bag. One didnt even depressurize the system and just did it live but it was gushing out for a couple of seconds.
Any advise will be gratefully appreciated. Once i have done this and confident i will do a few more and replace the old rads and incorporate some inhibitor.
