Changing a two way outside light and add a sensor
17 Apr 2019
I have two lights outside the front door . They are controlled by a switch in the porch but also can be switched on by another internal switch in the hallway of the house. How could I rewire the lights to include a sensor so that at night the would both come on when movement is detected but not during daylight ? Kind regards
So do you want the lights to only come on when movement is detected, and it's dark? What would you want the switches to do? Do you really want darkness unless movement is detected?
Have you looked at high-low lights?
Daft question to say the least
Not really, given the existing situation of lights with manual switches, an unclear objective vis-a-vis when 'ON' is wanted, and a suggestion that sensor enabled bulbs will provide the solution the OP seeks.
As mentioned , I can control the outside porch lights with either switch ie in the porch or in the hall , so in effect a two way switch . I have already invested in some ultra bright bulbs for the lights as the shades are slightly tinted ( so much brighter and more energy efficient ). What I was hoping is to add a sensor so that as it got dark any movement would trigger the lamps to come on . …what do I need to do this , how can it be wired and could I still use the two internal switches if required ? Regards
So in daylight hours you don't want the lights on at all, and when it's dark you don't want them on unless there's movement?
DAY​
NIGHT
MOVEMENT
OFF​
ON​
NO MOVEMENT
OFF​
OFF​
What do you want the wall switch(es) to do?
