Hi all
We've got 3 wall-lights in our dining room, and we're looking to replace with frame-mounted picture lights.
The picture lights have a small amount of flex for joining, and the lights are intended to give some freedom of positioning to the frame by leaving some free flex between the light and the wall socket - this is in preference to fixing the light to the wall, chasing cable into the wall, and having to shift it if and when the picture is changed for one in a different size of frame.
I am not sure which is the best way to connect the flex from the light fitting to the flex within the existing wall socket. I can see a number of ways of doing this, but I'm not sure if there's a 'preferred' way that I should follow.
I've found a number of fittings intended to allow flex to be exposed from the socket (example in link below), but I am still left with having to join the two lengths of flex - the flex from the light fitting is too short to reach the socket.
Link to socket fitting:
http://www.toolstation.com/shop/p26894
Any ideas or advice gratefully received!
