Can anyone tell me the work involved in doing this. I am thinking of doing the pipework myself and leaving gas engineer to connect at boiler. I Am confident I can do it as I have done all my radiators and had a gas engineer fit the boiler ?
From what I understand you remove the hot cyclinder and connect the pipe from the top of it to the hot on boiler. I will just be running the feed. The cold strage tank in the loft you remove and join pipes together. for mains in bathroom and toilet.
The F&E cap off.
When the cylinder is removed and the 2/3 port valves removed do I just join the flow and return together ?
The F&E cap off.
