Recently drained and refilled our open vented system with X400 to clean it out. It's been a long time since it was done. It went well. I carefully filled and then vented all the rads, but there's clearly air in the system.
What I think is happening, is this:
At the very top of our system (crown?) are two vertical 22mm pipes and a dome shaped AAV. From the top of the AAV, a pipe leads up and bends over the F&E tank, with about 30cm of extra height above the tank fill level. When the pump runs the rads get hot, and when the pump stops, I can clearly hear air rushing up the pipes, past the pump and into the U of pipe where the AAV lives. The fact this happens suggests to me the AAV isn't working, and that trapped air gets pushed down when the pump runs, then returns to the highest possible point in the system when it's off.
The rad on the landing - which I'm guessing is the very first one off the manifold, given it's location - gets a lot of air and has to be bled often, so presumably, the air gets pushed here first, but not all of it. Also explains why that rad makes a lot of noise when the pump starts. It's the air being pushed into it, bubbling in the rad, as it's forced down by water pressure.
The HTW is close to the pump too, and I wonder if some of that air is getting forced into the coil, making it inefficient; and explaining why our hot water is mostly tepid.
There's no manual vent anywhere near the AAV, on the tank feed, or the pump, making the landing rad the closest I can get to bleed air from the top of the system.
My plan is this:
Cut the two 22mm pipes below the AAV, and cut the pipe that leads up from it. Fabricate a replacement with compression joints that can slide over the two parallel pipes, with a T that leads upwards, and joins the pipe over the F&E tank.
But, where does the new AAV go in this configuration, and what's the best one I can buy?
My plan is this:
