I have two wall lights either side of a chimney which run off a single switch. I am wanting to replace these with 4 downlights (2 on each side) which will be fitted to alcove units that I'm building.
When I have removed the wall lights, there is a single cable running to each, so the loop in/out and switch cable must all be in the ceiling space above. My question is, am I able to daisy chain two downlights from the single cables that I have access to?
Dan
Dan
