Changingi Flue on Eurostar oil Boiler
5 Sep 2006
We have a Eurostar Floor mounted Oil boiler in our Utility room
110,000 BTU .
The Flue comes straight out the back Horizontally and through the Wall
On the Outside it is covered by a Wire Cage
The Problem is that there is a Window near this Flue and in the Fumes / gasses come through the Window
Also the Wall area around the Flue has turned Green because of all the Hot gasses / steam that get blown back against the House
Is there anything to stop me having the Flue changed into a Vertical Chimney fixed to the Wall and venting above the roof line ?
Is there a Kit available for this or is it even possible or allowed
Thanks in Advance
What is above the ceiling above the boiler?
The Utility room is a single story addition to the house with a Pitched roof
( Slates )
Above the ceiling there is just a small loft space
I was hoping it was possible to convert the Horizontal Flue to a Vertical outside the house using a 90 degree bend then going up the outside wall
But i will be guided by those who know about these things
