- Joined
- 27 Jan 2008
- Messages
- 27,618
- Reaction score
- 3,335
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I want to charge a leisure battery from the car to power items in the caravan. Although only two towing cars in the family there are many more cars of people who may want to use the caravan so it would be an advantage to be able to fit the charger in a range of cars the cig lighter socket would be favourite. The unit I found is rather expensive at £100 approx, and it is not really designed for the cig lighter socket. It has two live feeds from donor battery one for power and other sensing battery voltage, and one negative ground which means it needs a really good ground to ensure as it switches on the volt drop will not turn it straight off again.
Clearly if the battery became flat one could have two crocodile clips and run the car at fast tick over to re-charge battery. However you could just as easy use jumper leads with same results. The wiring diagram is shown below.
There is clearly a balance between cost of unit and performance and 12A does seem to be reasonable if one leaves the caravan to visit local attractions likely one will have engine running for an hour so that's 12AH which should be enough to keep water pump and one light working assuming fully charged to start with for a month. I use a solar panel to stop self discharge problems but to get one large enough to keep battery topped up when parked under trees is rather expensive. At the moment the solar panel is direct vie internal diode with no regulations at 0.1A not a problem but as the size increases then one also needs a PWM or MPPT regulator and this also has problems with battery charging when the battery is also used.
I tried charging batteries on a narrow boat and realised there is a problem when the battery is used as the battery voltage does not only raise and fall due to charge rate but also due to usage and with the heater on the current did not drop below the 5A needed to switch the charger into float and the battery voltage was held high until the timer switched to float and then would under charge until it reached the reset voltage and restarted the cycle.
So only way was to have two batteries one in use float charge only and one on standby on stage charge each day swapping battery being used. OK with narrow boat and 4 x 160AH batteries that was OK but don't really want two batteries in the caravan.
Although as I have said running car engine with jump leads between car and caravan battery will to start with put a reasonable charge into the slave battery but this will quickly reduce and only with a stage charger of some type will a battery be charged in a reasonable time.
My thoughts were this is not a new problem why re-invent the wheel there must be products already on the market. However my thoughts then turn to the narrow boat again. Traction batteries used in fork lifts, mobility scooters, golf trolleys etc will last for around 7 years however listen to narrow boat owners and batteries were only lasting around 2 years clearly they were sulphating due to not being fully charged where the charger was foxed due to using items off the battery while being charged.
Sterling did do some really fancy systems with a pulse charge which would work with a battery being used and charged at the same time but the price was something else.
There was an attitude we have always done it this way we know best and narrow boat owners would talk a lot about how to care for batteries but in real terms as shown with battery life they abused the batteries and killed them. Likely I will get same from caravan users although since at some time of the year the caravan will likely return home and battery charged plus removing a 60AH battery and charging is some what easier than with a 160AH battery so owners will tend to remove battery for charging in the winter.
However on this forum we have some thinkers who do not just say that's how we have always done it so that's the way to go but think outside the box.
So this year caravan was on a site with hook-up so no problem however next year likely we will be looking at a cheaper site without a hook-up and the family will take it in turns using the caravan so looking for comments on what is available and cost effective ways to maintain a battery in a usable state.
What was wrong with gas lights and foot or hand operated water pump? Years ago the battery was not required it just made life easy. Today no battery means no lights, no water, and no heat even the fridge and cooker use the battery to light the gas.
