Cheap and cheerful!
23 Sep 2009
Durham
Have just created a utility room by partitioning off part of the back of my garage. Partition wall is 1200 x 2400 plasterboards. want to paint wall but dont want to skim it - will be mostly covered by units and the room is rough and ready anyway (other 3 walls are bare brick).
What is the shortcut? Some kind of filler I can past over joints/screw heads that can then be painted?
Advice appreciated. Thanks.
How noticeable are the joins? Square or feathered?
Did you use screws or nails?
Galvanised or just steel?
joins are not too bad - just used standard plasterboard so edges are slightly rounded but not chamfered.
used screws - the horible black drywall screws from screwfix that fill your fingers with splinters!
if youve used square edge it doesnt matter what u do ull see the joins unless you skim it because even if you use joint filler when you rub it down and paint it you will still see it needs to be the feather edged boards for drylining if its 1 wall a plasterer wouldnt charge you much where are you ill come and do it for ya!!
I have a mate who will skim it for me for free but I didnt think it was worth the hassle as I am not really bothered about the appearance only making it a little better than bare plasterboards!
Might even have a go at skimming it myself as it wont really matter if it is a disaster!
Thanks for the advice anyway!
If you don't want to skim, then:
1) Fill the joints as best you can, and rub down.
2) Paint the screwheads with aluminium paint, then fill & rub down.
3) Paper with heavy-duty lining paper.
4) Paint.
