- Joined
- 27 Jan 2008
- Messages
- 27,401
- Reaction score
- 3,307
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have a problem with mothers room getting too hot, opening a window can cool a room at night, however during the day it can actually be hotter outside than inside, so there are times when opening a window actually makes a room hotter, so thought is fit a fan to blow air into the room from outside and use thermostats to control it.
10 am and camera is showing 29°C at the moment, but eTRV is showing 21°C so it is direct sun on the camera, outside 20.2°C so no real point opening window now, left it too late. So something automatic is called for.
So easy enough to use something like the STC-1000 pick them up at around £10 set it so if inside exceeds 22°C turn on fan, however could be blowing in air hotter than already in the room, so looking for something with two sensors which will work a relay according to which sensor is hotter.
Sure I could make something, but if there is a cheap one already made then I would go for that.
I can find them for USA This is 110 volt so not any good for me and also 12 volt versions, but looking for something like this
but 230 volt version. Think used for solar water heating, but for 230 volt only found them at silly prices, could buy an Air-con for less.
