Check valve. Do I need one?
20 Jan 2011
Cumbria
Will be installing a vanity unit this weekend and it will have a mixer tap. Do I need a one way check valve on the cold pipe.
Thanks.
Your link does not give much of any detail on the tap unit that is to be fitted.
IF the tap is of the type that allows the water to mix within the body of the tap, and most usually are, then check valves will be required on both the hot and cold where the supplies are of un-equal pressure.
ultimately you should refer to the manufacturers details to check the type.
Can't find any info on the tap which appears to be unbranded. Unmarked box with no details inside. Have taken the end off the tap and it looks like the water mixes in the body. Have connected the pipes to the tap and I can blow and suck through both easily so no valves fitted internally.
What you describe comes as no real surprise.
You would be better fitting check valves to both supplies or better still providing a cold supply from the storage cistern to give balanced pressure and prevent backflow issues.
Running a new pipe isn't really an option. I'll fit single check valves to both pipes and hopefully get good enough flow.
Thanks for all the replies.
You certainly don't need a check valve on the dhw. The air gap in the dhw header gives more than adequate protection to the cold main for this. additionally the flow rate at the tap will be signinficantly reduced by the resistance of the check valve.
Your hot water represents a fluid category two risk, which means that strictly speaking the cold main should be protected by a suitable fitting which a single check valve represents.
In practice I know of very very few plumbers/housebuilders etc who ever fit them.
Your choice really.
You certainly don't need a check valve on the dhw. The air gap in the dhw header gives more than adequate protection to the cold main for this additionally the flow rate at the tap will be signinficantly reduced by the resistance of the check valve.
The air gap is irrelevant when the hot and cold main supply is mixed within the body of tap!
Agreed ref the reduced flow hence suggestion re routing supply to provide balanced flows thereby eliminating need for check valves.
A check valve on the hot wouldn't be for backflow prevention, it's to stop mains pressure water going through the tap and up the hot supply into storage cistern causing overflow to run.
A flap type nrv will give hardly any restriction to flow.
the air gap is not irrelevant. it is what protects the mains on the hot water side eg at the tank. the protection to the mains at the tap is being offered by the check valve
re cross flow depends really on type of mixer really.
I haven't heard of 'flat type' nrv. What's one of these then?
