Knew that if I put breast in the title I'd get more people viewing..............
I have a victorian property and want to put a cast iron fireplace in as there's nothing there at the moment - just a neat fireplace opening .But this space is a little too small height-wise. The old fireplace had been taken out and the fire opening "tidied up" but when the builder did that, to keep everything symetrical he'd lowered the height of the opening by putting in a concrete lintel about 3 cm lower than the original chimney arch.
As far as I can make out (by probing in the mortar under the arch) the iron bar that the victorian builders used to put in under the arch isn't there.
What I'd like to ask is....was that iron bar just formwork to keep the brick arch in place while the mortar between the bricks was going off or was it necessary to support the weight of the bricks above.? I would have enough room to put my new fireplace in if I took out the concrete lintel and I'm thinking that the original brick arch would be enough to support the weight of the chimney breast above (single skin and about eight foot above the arch) - after all that's what arches are for isn't it?
But thought I'd better check first! Any ideas?
