Brick arch in chimney breast
11 Jan 2013
Durham
Disappointingly, the arch in the chimney breast has been removed/bricked up by others when installing a rather nasty fireplace.
I fancy reinstating it- main question is whether the metal strap usually supporting such arches is steel or wrought iron. Yes I could just put a lintel in (be a 3kw woodburner going in eventually) but it won't look as pretty.
3 Aug 2022
Worcestershire
The metal bands are needed because usually the brickwork pillars at each side are only 1 brick thick. This doesn't provide enough mass to resist the thrust of an arch, so the metal band acts to hold the arch together. (https://www.idostuff.co.uk/sections/DIY/Chimney Arch/Brick_Arch_self-corbeling.html)
These would be wrought iron but you'd be hard pressed to find modern wrought iron (what is usually sold as wrought is actually just mild steel but worked on by a smith).
However... I'd personally pay a bit more and get an arched steel lintel fabricated. http://www.harvey-steel-lintels.co.uk/archlintels.htm
The arch tie approach isn't really used anymore - beam lintels are more robust.
11 Jan 2013
Durham
How about re-instating an arch using a plywood former/frame?
No need for a lintel then.
Thought about that, slight paranoia about Edwardian builders must have had a reason for putting those straps in on the fireplace.
11 Jan 2013
Durham
Ahh, good point. Not got that far into the breast yet so don't know. Ta for the links.
2 Jan 2012
Nottinghamshire
Interesting, I would have thought that the downward load acting on the brick pillars, taking into account half all the load of the full chimney breast above it ( except for the inner section of corbelled brickwork) would have been more than enough to counter the overturning horizontal force exerted by the bricks contained in the corbelled section and even more so as the sides of the chimney breast would be keyed into the adjacent wall, although the shear forces within the mortared bricks and the actual dimensions of the opening would be further factors for consideration. A quick easy former seems to be the most logical reason.
11 Jan 2013
Durham
From other brickwork in this place I wouldn't put money on the sides being keyed in!
22 Nov 2009
Oldham
Put a single leaf steel lintel or angle iron a bit higher up to carry the load then build your "cosmetic" arch underneath. Those arch lintels aren't cheap.
3 Aug 2022
Worcestershire
The arches tend to be shallow which makes the horizontal component larger.
You can try it but I wouldn't bet my safety on 9" of masonry resisting much lateral load of anything.
2 Jan 2012
Nottinghamshire
Yes, I guess it whether a lateral force of 1/2 the weight of the corbelled brick section (max it could be) would push the pillar over?
11 Jan 2013
Durham
That's sounding like a winner- will come back once I've pulled the nasty fireplace out the way & let you all know what I find.
