Hello Folks
Lurking for a few years, now I have a real job of my own...
The house is late Victorian early Edwardian semi, solid wall construction (actually, outside layer is devastatingly hard engineering brick).
I have only 380mm depth in the builders opening (rear wall of opening to face of plastered wall).
The cassette stove is a Stovax Elise 540 - it's 350mm deep, until you read in another section of the manual that the frame sticks out a further 35mm from the flange from which the 350 measurement is taken... Hmm...
OK, deep breath... We actually went for the 540 because the preferred larger model (680) has a depth of 395, so now that the 540 doesn't fit perhaps there's an opportunity...
Considered solution:
Insert a lintel in the inner layer (wythe) of bricks in the wall and make a rough opening below it, behind the stove. There's one course of headers that would have to be cut back (engineering brick!). That would leave only the outside layer of bricks directly behind the stove. I'm considering filling the opening with something like Vitcas ceramic board for heat proof insulation:
http://www.vitcas.com/ceramic-fibre-board
That would give me an extra 85 depth in the builders opening (110 brick depth - 25 ceramic fibre board depth) and a total depth of 465 from the face of the plastered wall. That's 80 behind the 540 model stove, and... 35 behind the 680 model stove
I'm interested in any comments on the feasibility of this and any major (or minor) disasters foreseen...
Thanks, Morgan.
Thanks, Morgan.
