Choice of ceiling grilles/vents for in line ducting
22 Aug 2010
London
Hi Guys,
Not sure of the best forum, but will try here and building. Anyone got any views on the better of the ceiling mounted vents for ducted extraction in a bathroom? There seem to be two popular options.
One is the grille type, i.e. lots of small holes and the other is a circle in a circle, where the inned section can be adjusted for flow.
The latter seems more visually appealing, but I cannot get my head around how a 100mm duct and fan througout then comes through a smaller ring of an opening. Does this simply mean increased air flow at this point?
Just after people thoughts.
I fitted the latter as it looks a lot nicer, and if the pipework gets dirty inside you can't see it!
From experimenting adjusting it, the smaller the gap (within reason), the higher the pressure.
