Choken pipework, no hot water! (Now with diagram)!
30 Mar 2008
Glasgow
Hi guys this is the scenario
Combi boiler, working fine. Hot water in kitchen is flowing OK. NO hot water in the bathroom at both WHB & bath. There is no blenders or anything. The pipework is under a tiled floor, could it possssssibly be choked?? Anyone seen this before? Whats best way to clear, I tried blowing it back using a hose on the coldmain at the bath no result! Its just weird that it can choke the pipework after coming through a boiler and that ?
Combi boiler, working fine. Hot water in kitchen is flowing OK. NO hot water in the bathroom at both WHB & bath. There is no blenders or anything. The pipework is under a tiled floor, could it possssssibly be choked?? Anyone seen this before? Whats best way to clear, I tried blowing it back using a hose on the coldmain at the bath no result! Its just weird that it can choke the pipework after coming through a boiler and that ?[/quot
problem the diverter valve , if you have water coming from hot tap in bathroom there is no blockage
Would you not have a problem trying to back flush main water up the hot water tap in bathroon when connected to a combi.
If hot water pipe is linked with bath and basin tap and kitchen, perhaps you should open the hot tap in the kitchen and then back flush at the bath. This would allow water to flush through 'backwards' and escape through kitchen tap.
Does that make sense :?
I said theres water at the kitchen, but none in the bathroom.
Here is an image of this,
KITCHEN SINK - IS GETTING HOT WATER.
BATH & WHB - NOTHING.
all the floors and walls are tiled.
If there is a blockage between the combi and WHB/Bath you can not back flush back to combi and sink because the water has nowhere to go. Hence either disconnect combi or as said and easier open hot tap at sink.
