Choosing UPVC window supplier
19 Nov 2008
Dorset
I'm going to replace some sash windows from an Edwardian house, and would like to know if there are any recommendations, for suppliers, please. Nothing special, just practical and best prices.
Camerart.
Sacrilege! replacing sash windows with uPVC in an Edwardian house!. They will never look right. OK, uPVC is cheaper, and maybe needs must, but still sacrilege...
Hi Mr M,
I agree, but this is a cold house, and I'm feeling it these days.
Previously my house was listed, and I 'made' some sash windows, as they had to be sash.
C
Ha! so did I - 8 windows for our Edwardian. However, mine were made with 56mm sashes so they could accommodate 24mm DGU. The whole window designed to dimensions to take the heavier weights, and with draft proofing strips all round. Windows perform as well as any other DGU.
Not an easy task, but if you ever felt like having a go, I'm happy to share tips/drawings. there's a thread here of journey on that project! https://community.screwfix.com/threads/talk-box-sash-windows.183451/
Hi Mr R,
I cheated, by getting some old larger sashes, and cutting them down, following how the joints are (I'm not a carpenter) then made the side boxes.
As mine were shorter, the cast iron weights weren't heavy enough, so I cast square lead ones.
A bit of fun:
I needed some pullies, and when walking past a demolition site, I told the site manager to save me the pullies, when they got to them. These windows where 8' high and had chains not cord. Anyway, he went over to the massive JCB, and he squeaked over to the front of the house, and proceded to pull the two story, bay windows off the building, then to my amusement hooked each chain/weight/pully and placed them in front of me. I was dumbstuck :)
I'll go through your link later, as I may try DGU.
Thanks. C
Rehau heritage with mechanical joints are pretty decent.
I'm not a carpenter
Nor am I, but I've discovered over the years that with research, the correct tools and a "have a go" attitude, it's possible to do things you didn't think you were capable of.....
Have to say, they do look good. I've fitted Rehau windows recently (not sashes) in another project and they're decent.
Hi Mr R and G,
It's not often I get messages from G, but Rehau heritage do look 'right', thanks.
Yes, I had an 8year "have a go" nightmare, but as above, there were lots of redeeming events, that I can now look back on with affection.
I was surprised that I got so much advice and demonstrations from all building trades, which made it possible.
Any idea about the prices? Bay window and usual simple oblong type.
C.
No, but rather than phone a "window" company, to keep the cost down it might be worth finding your local Rehau trade supplier and asking them for a supply-only quote. My local one is http://lostockhallglass.co.uk/ but they're a bit far from Dorset....
Either fit yourself (which isn't that difficult), or find a builder/handyman capable of fitting windows (if it's a bay, is the existing bay window structural - many timber ones are), or are the bay posts brick/stone?). If the fitter isn't FENSA/CERTAS technically you should do a building regs application if you don't use an approved fitter, but with the units on supply-only you'll save the window company's overhead and profit on the units so the ~£250 BR fee might be worth it... - Depends on your attitude to warranty - which you obviously get if you have a window company do the whole job.
If you have existing sash windows you'll need to pay attention to the detail of how you work with the existing reveals currently housing the sash boxes. You could fit the new windows into the outer skin (which IMO can look odd) and then just build out the reveals, or you could re-work the reveals so that the new windows sit where the old ones do - just slightly behind the outer skin as the existing box sashes are likely to be, so they "look" right.
If doing this pay attention to the lower corners - the old box sash cills will be shaped so water runs out over the (stone/brick/tile) cill, which is likely shaped to deflect water outwards. If changing to uPVC you don't want any water running round the existing cill into the wall structure. Even if there is e.g. a stone cill, you'll most likely need to specify new uPVC windows with a cill (which come in different sizes) rather than without., and take care with the detailing of the lower corners.
When I have blocked in a box sash reveal to take a standard window, I've used thermalite blocks (easy to cut) and mortar (remember to fit a damp proof membrane where they touch the outer skin bricks) then fitted the window and then finished the inside. If they are sash windows they may well have architraves around the internal window opening, so you might have to plan to re-work these too.
Either way, replacing box sashes with uPVC you are almost certainly going to have to do some associated builder/joinery work, and window fitters may not have the inclination to do the best detailed job (they'll do the fastest job).
Apol if I'm teaching a grandmother to............
Hi Mr R,
Thanks for that, I'll take note.
I have a couple of 'how to' Youtube vids, that are really helpful, I learn best by watching.
Cheers, C.
We installed these rehau vs. Top window is a r7.
