chrome waste pipe
9 Aug 2009
Blackpool
hey I was wondering if inch and a quater chrome waste pipe will push in to normal plastic inch and a quater plastic push fit fittings and seal or if you need special fittings. Thanks for any help.
Unlikely it will seal on pushfit unless it is specifically designed for it.
it should, but you can get chrome fittings you know, might look nicer
ok the fitting its goin in to is going to fall in the wall. I was just thinking of cost reali.
Most chrome/copper will be 35mm and not 32mm.
In other words you need to check the trap etc, and go from there.
And yes you can get universal adapters for chrome/plastic
