Cistern stuck during filling
26 Mar 2012
Avon
I have a 10 year old push button cistern. During filling up it sounds like it is filling which is constant. Taking the lid off the water is stuck at 2 inches in the bottom. If you move the lid around after a minute I hear a whoosh sound and then it fills normally.
What part do I need to replace?
Many thanks
After flushing ,does water actually come into the cistern from the float valve ? If it doesn't replace the float valve.
If water is coming in ,but the level isn't rising ,then it must be continually running into the pan and the flush mechanism ( flush valve) will need servicing ,or replacing.
Fixed it for ya
If water is coming in ,but the level isn't rising ,then it must be continually running into the pan and the flush mechanism ( flush valve) will need servicing ,or replacing with a traditional, reliable, stood-the-test-of-time mechanism.
Yes water is flowing into the pan but cistern level not rising. Will go for a new flush valve.
Regards
cyclopse
