Clarification on Gas Fired Combi
17 Oct 2010
Manchester
I have a BAXI combi boiler used for water and central heating.
I have 4 radiators fixed with Drayton TRV.
These are my clarifications.
1. My radiator valves has only thermostat mode and does not have a switch off mode. Can't I never switch off my radiators?
2. I had noticed that irrespective of keeping the radiators in thermostat mode or on mode, the number of units consumed is always same
3. One of my friend was telling that atleast one of the radiators should or will not have valves since the water always needs to go atleast one radiator at all time. Is it true? He said otherwise the water will be blowed up nowhere to go.
If this is the case, why all my radiators have valves and am i not supposed to switch it off or keep in thermostat mode.
4. There is a boiler heating control and individual radiator valves in radiator. How does both gets into sync. For eg., if I keep the boiler central heating to 60 degrees and radiator valves to number 1, does it make any difference.
So you have TRVs on all radiators?
The numbers on a TRV represent room temperatures. The valve automatically controls the water flow through the radiator to maintain the required temperature.
Presumably the lowest setting on your TRV is a *; this is the frost setting. If you set the TRV to the * setting the radiator will stay closed until the room temperature drops below about 8degC
If your TRV has a 0 setting this is normally a positive OFF setting.
What do you mean by "on mode, do you mean set to Max? The number of units consumed will depend on the outside temperature and what temperature you want to maintain in the room. Setting the TRV to 1 should use up less gas than setting it to Max.
One of my friend was telling that at least one of the radiators should or will not have valves since the water always needs to go at least one radiator at all time. Is it true? He said otherwise the water will be blowed up nowhere to go.
Some Baxi boilers are designed to work with TRVs on all rads. Which boiler do you have?
Setting the boiler control to 60 just controls the maximum temperature of the water flowing round the system. Setting the TRV to 1 means that the valve will maintain a room temperature of about 12degC.
