I have trawled the web but cannot find an answer to this.
I'm convinced the boiler (14 years old) isn't reaching the 82c which the manual says it should and would, therefore, like an opinion on where the problem is most likely to be. There's the control knob (potentiometer) on the front and a pcb inside, I guess the gas valve is also part of the equation (and probably more besides)
The control knob is just a potentiometer but, in a recent visit, an ex-british gas plumber reckoned it was one of the most common faults along with the thermostat sensor (which I asked him to replace) - he's also got the potentiometer but hasn't fitted it yet - he doesn't want to charge a callout fee for a £10 part so will fit when he's in the area again.
I have read that the control PCBs sometimes suffer dry joints. I can get a reconditioned pcb for about £50 (with warranty) and am contemplating buying one so the plumber can fit it when he comes next.
I have strapped digital thermometers to the flow and return pipes on the boiler and recorded the temperature over a 24 hour period. It would appear that the boiler output peaks at about 65c (manual says it should do 82c) but the boiler feeds a boilermate 2000 and the store temperature rises to 73c (at times) - so a discrepancy in the thermometer readings which could be due to them being taped to the feed and return pipes - maybe.
However, the BoilerMate store temperature should be between 74c (call for heat) and 77c (satisfied). So it looks to me like the boiler isn't delivering the goods anymore.
I have recently added x800 after cleaning the CH F&E tank (full of crud) and am about to drain the system down to add x100. (Might wait till the pending cold spell has gone).
Sorry for the long post - better than drip feeding I think.
So, back to the main question, what do you think is the most likely cause of the boiler output temperature being low?
many thanks
many thanks
