Clearing panel log - Enforcer
17 Jul 2018
How does one clear the panel logs without ending up clean starting the panel settings to either graded or ungraded? 2000 / 2020
It reads as though even when just wanting to clear logs through the CLEAN START menu this is inevitably going to reset a lot of the settings I’ve put into the panel myself?
The panel log shows that the log is nearly full... If there’s no way to clear it without undoing settings what’s the impact of the log becoming full? Will it just overwrite oldest log first or?
It will overwrite it ...it will keep the last x amount of log data .....also when normally do a clean start it asks you if you want to delete .....programming , codes , log ect ....
