Click Clack waste leaks
13 May 2004
Cambridgeshire
Had Click Clack wastes fitted in new bath and basin when we had our new bathroom installed recently and both leak slightly (can't leave a face cloth soaking in basin for long as water disappears and can't run a bath in advance if you want it to remain full). I'm no plumber and we had such problems with the bathroom fitters I never want them in my house again............ Is this yet another fitting cockup by them?
Any advice gratefully received.
Regards
Amelia
Do you mean the plug doesnt go down enough for it to create a seal and keep the water in?
If so there is a screw on the bottom of th actual plug itself which you can adjust, screw it in so the plug sits lower.
Perhaps that is what I mean. I'm not familiar with the way they fit, but that makes sense, yes. Will have a look at that. Thank you.
I have had a look at the bath fitting and I can see the screw you mean so will deal with that.
When it comes to the basin it appears to be a different fitting. No screw at all. Under the chrome cover which you press to pop up and down, is a black seal and a piece which looks like a little cage (poor description but I can't think how else to describe it) which fits into the hole in the basin. The piece with the holes, like a cage, comes off if you pull it. When you click down you can see it doesn't seal and hear the water trickling away immediately.
Any further suggestions?
Many thanks
Hi Amelia,
I was just wondering if you got your waste problems fixed as I've got excatly the same problems, including the ones you had with your installer!!
Any tips for sorting are welcomed, as I've no plumbing skills at all.
