Cold fed to a fridge
12 Jan 2009
London
What size supply does a fridge freezer need??What kind off isolation valve do I use on it aswel??
ours came with all the relevent fixings up to the point where it meets the standard 15mm cold feed that your house likely already has.
was it a copper or plastic supply that you'd have for a washing machine?? Cheers for the reply thou
our fridge came with a reducer from 15mm down to what looks like about 8mm clear tubing which then feeds into the fridge. I put my own isolator on for obvious reason (ie. moving the fridge etc)
