ive got a job to do customer asking for a combi boiler fitted can anyone tell me what inlet presure it will need to fire i know its normally 1bar what about cw flow rate
Most modern combis will work down to 0.5Bar. You havent said what siz combi it is so as long as you've got around 15 litres/ min should cover most adequately.
Presumably as with most 28Kw combis this will give around 12 litres/min @ 35 rise, so with about 1 bar pressure and 15 l/min cold there should be enough water to use it .
