Hi, Just had a new bathroom fitted which included a shiny new towel rail. Since then however the hall rad is stone cold! I made sure both valves were open which they were. I then bleed the rad but no air came out, just water. checked the TRV pin but that is moving freely. Both pipes to it are cold. I bleed all other rads in house just in case (they all work fine). Standard boiler/hot water tank/gravity fed system. Also had fancy pumped shower installed when bathroom was done.
Think i may have an air lock??? How else can i get air out of system?
Any help/advice would be much appreciated.
