All the radiators are fine exept one in my bathroom.I have red the comments about this and i think it is sludge.Can i remove the radiator and flush it with a hose pipe or do i need a system flush.
At the end of the day you may well need the real thing, but there's nothing to stop you doing what you suggest...just make sure that both valves can be fully turned off first though! Then, rad off, flush both ways with a hose, and see how much gunge comes out...then, shallow tray under the valves, open them and if your luck is in you'll get horrible black water out. Continue with this until it comes clear. Remember though, you'll lose the inhibitor if there was any in there in the first place. Cheers John
