I have a Megaflo cylinder which is probably 20-25 yrs old. I recharge the air gap around every 6 months. All my taps and showers are direct-fed mixers. Thought I might have a problem when hot water from cylinder (pipes there are both hot) is coming out of mixer taps either cool, warm, sometimes hot and sometimes just cold, intermittently when set to hot. From what I’ve read so far, it may be a failure at one of the mixers/showers, leading to a crossover? I went to recharge the air gap today and having closed off the cold supply to the cylinder, the water was draining outside continuously forever via the tundish? Gurgling never stopped. And nearest single mixer tap which was set to run hot simply wouldn’t stop running at all. Gave up. As the cold water feed to the cylinder was isolated, I couldn’t understand why the cylinder didn’t just run to empty unless the isolator has failed? Or was the cylinder filling up via backflow from crossover? (If that’s possible?) I will most likely end up getting an engineer in but would like to narrow the issues to speed up any necessary repair. I’ve got 2 washing machines and 2 dishwashers in different parts of the property but all are cold water feed only so don’t think there will be any crossover/failure with those.
1. Not sure what’s the best way to try and identify which mixer tap/shower might be at fault? - Main issue
2. Should there be a non-return valve fitted to hot supply to each tap to stop cold getting in to hot? (Or is that pointless?)
3. Could it be a problem with the Megaflo cylinder? I had mains feed PRV replaced about 2 years ago after it had failed and thermostatic safety switch replaced last year after it kept cutting out. CH zone valve was replaced about 6 weeks ago. H/W zone valve, pump and gas boiler all activate correctly when switch calls for heat or if cylinder thermostat temp increased. Open to all suggestions…
