The last time this question was asked was in 2004, unfortunately the answers have not been any help.
My cold water tank is being filled from the hot water tank. The system has been in place about 15 years. Both tanks are in the loft with the cold water tank raised on a platform. It is an indirect system.
I know it is filling from the hot water cistern because I turned off the feed from the cold tank and the overflow pipe from the hot tank started dripping into the cold water tank. The feed pipe is also quite warm near the cold water tank, which seems odd. In fact near the hot water cistern the feed pipe is warmer than the outlet pipe at the top.
I have read that it may be a faulty mixer tap. I only have one and turned off the cold feed to it but still got the overflow.
Any ideas? Is it a faulty hot water tank? What else can it be?
