Hi All
I'd be grateful for some pointers/advice as I am struggling to get an issue resolved.
Boiler is a Broag/Remeha Selecta combi, HW works, CH does not.
So far the plumber has replaced the diverter valve and its actuator/motor and now the main heating pump.
Still no CH. He thinks it's a blockage in the heat exchanger but this sounds more like a best guess.
Thermostat is calling for heat, signal received ok, boiler won't fire. Pressure is 1 bar approx.
I'm not sure why a blockage would stop the boiler firing up? I can understand it might cause a lock out if something overheats but it's not firing at all when CH is requested.
Historically it does make some loud vibrations, prior to the above parts being replaced, and the overflow has dripped a little (outside the house) but generally has been reliable until now.
Any thoughts? My plumber is about to concede defeat.
Stuart
Stuart
