Combi boiler failing to light: pressure: 0 bar
22 Aug 2006
Berkshire
Hi all: I'd be really appreciative if someone could give me some advice here.
I've got a Worcester 24i combi boiler which last night failed to light for hot water. However, this morning - having expected a cold shower - it produced hot water!
The thing that worries me is that the pressure is reading 0 bar, even though today it is working normally.
About a month ago it discharged a largeish amount of water which worried me but I thought that this might have been due to some overflow valve. It has not done this since.
Any ideas?
Cheers,
MB
Clearly the system pressure needs restoring to 1 bar. See the FAQ topic for details. Check that it isn't discharging water again when repressurised.
There's no pressure switch though, so low P wouldn't have stopped it working before, so something else is wrong.
Overheating due to lack of water in the primary part of heat exchanger? I thought it best to eliminate the system pressure issue first anyway.
It might have noticed lack of flow of water - and not overheated, just not worked. But there seems to be enough water for it to go now. :?
Anyway, fillerup and see how she goes.
