- Joined
- 18 Aug 2025
- Messages
- 171
- Reaction score
- 3
- Country
Hi guys so i have touring caravan on some private land its only going go be used by me no one else and its not going to leave my land.
im looking for some advice
im looking at fitting a small say 24kw lpg combi boiler so i can run a radiator inside
i feel im a competent at soldering and plumbing work ive done quite abit of it
what i want to ask is i dont want to run mains cold water to the caravan and i dont need running hot water from the boiler i only want to use it to run the radiator ,
a heat only boiler would likely be more efficient but i presume that would require a tank and expansion etc...
so can i ask after the initial filling of the wet system can i blank off the cold in and hot out on the combi and it would work fine or is there issues that could happen using the combi in a heat only setup ?
