Update and question (!):
Hello all
So I've had a week or so without heating or hot water and am about to run myself a nice hot bath!
I replaced the pump with a used/tested one from eBay (including manifold which I didn't use), (£50 inc postage). I now had hot water for a few seconds before the H3 error code appeared and, after a few switches back to 'D', shut the system down. Taking Shambolic's advice, I sent off for a DHW thermistor, which I've now fitted. I was a bit of a pain in the proverbial because the old one was not going to come out (it's a push fit with a clip). So I decided to remove the plate heat exchanger so I could push it out from the other side. Unfortunately the torx screws were in a bad state so I had to drill one out and cut a slot in the other to unscrew. I found some hex replacements at B&Q. While the plate heat exchanger was out I left descaler in to soak for a few hours and got some chunks of scale out.
So here's my question:
Touch wood I now have heating and hot water. I've got a couple of things still to do, eg add inhibitor, maybe bleed the pump, empty condensate trap etc, but more pressingly, I note the water pressure (hot AND cold) has dropped, well the flow anyway. I wonder if a loose piece of limescale is sitting in the heat exchanger and that's what's slowing the flow. However, I think it a bit odd that the flow is reduced for the cold water too - no limescale on that side of the PHx. Before I drain down and remove and pressure wash the PHx, I wondered if you folks have other suggestions as to possible causes!
