    Dismiss Notice
Combi Boiler Shower help
Discussion in 'Plumbing and Central Heating' started by sttdci, 13 Mar 2020.
  1. sttdci
    sttdci
    13 Mar 2020
    Thanks Received:
    Country:
    I currently have an Aqualisa Aquastream pumped shower on a gravity fed / water tank standard system. I have read that you can't have a pumped shower with a combi boiler but I want to swap to a combi boiler before getting the showers replaced.
    So my question is can you just not have a pumped shower under any circumstances with a combi boiler or is it that you can not have a shower with the pump running ?
    I have an isolator switch to the shower which will stop the pump running so could I still use the shower with the caveat that there might not be much pressure etc. until I get the shower swapped out for a combi boiler compatible thermostatic shower ?
    Thanks in advance for your advice
  2. denso13
    denso13
    22 Jan 2007
    5,632
    Thanks Received:
    1,118
    Country:
    A pumped shower is for low pressure supplies but a combi will give you high pressure. Not sure if it will work at all with a combi.
  3. Sponsored Links
  4. ianmcd
    ianmcd
    15 Aug 2010
    23,536
    Thanks Received:
    9,737
    Lanarkshire
    Country:
    you will have to remove the pump, most pumped shower valves can cope with a combi, not all though
  5. Madrab
    Madrab
    4 Oct 2012
    8,244
    Thanks Received:
    2,356
    East Renfrewshire
    Country:
    Would it work, probably, will it give you enough flow, wouldn't know until you try it I guess.
    Given the Aquastream is a power shower and looking at the way it pumps, you may not get much flow at all as you wouldn't be able to remove anything to allow it to flow better.
  6. Sponsored Links
  7. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,760
    Thanks Received:
    5,081
    Cheshire
    Country:
    Maximum static pressure is 1 bar so it’s a no from me.
    They’re not designed for that scenario.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
