combi boiler
4 May 2007
Manchester
when i turn the central heating on the boiler switches on for 3 secs then the flame goes out .i was told it was the air pressure switch so i replaced it i also vacked out the venturi where the 2 rubber pipes go in .so i connected all 3 wires together on the air pressure switch, and the boiler runs fine .could anyone help me.
No help here try the N.H.S helpline and ask for Psychiatric help.
You are clearly a danger to yourself and to your boiler.
You have bypassed a safety device!
Presumably you are a tenant from hell as no owner occupier would rish his property like that.
If you dont already know doing something like that which you are unqualified for will invalidate your insurance.
I am not going to risk giving you any further information but had I been going to it would have assisted if you had stated the make and model of the boiler.
Tony
Tony
:shock:
What the hell are you playing at!
I hope you dont live near me.
Listen to Tony and scatman, as they will probably SAVE YOUR LIFE
Dave
check fan,flue ,case seals , lastly suspect pcb
