Combi compact hre 28/24
8 Aug 2016
Boiler is showing pressure at 0.0,
Tried filling from the loop but it does not change at all.
I cannot access the clock to check if the time is correct, because of this.
I have hot water and heating.
Any ideas as to what is the problem?
It was doing exactly the same before the sensor was changed and changing it didn't resolve the issue
Are you sure you don't have a leak?
These boilers will run perfectly happily with the pressure sensor disconnected
No signs of a leak,
I might have a look tomorrow and disconnect the sensor
No signs of a leak,
Do not do that.
Disconnecting the sensor- is for open vented. You want to kill the boiler, go right ahead
Do you know for a fact boiler is not ejecting the system water? If the previous pressure switch was replaced because it was blocked with crud, no reason why same sediment could not be the case of system
Losing pressure
I can see any signs of ejected water.
The old pressure sensor wasn't blocked as far as i remember
I have heating and hot water.
I believe the system is full, bled the rads and no air escaped at all.
There is no fault light displaying as per the manual.
