combi flue making noise in the wind
4 Nov 2010
Sheffield
Hi
We have just had a new combi fitted and the wind is blowing over the end of the flue and making a noise. The only thing I can liken it to is when you blow over the end of a bottle and it hums. This can be heard throughout the house as its quite a low hum and is keeping me awake at times.
it is a standard flue with a round straight cut end. It does seem to have a diffuser just inside the end but this isnt working very well!
Any suggestions welcome. The installer is looking into it but he has not heard of it happening before.
Al
hope it's not turned on
just couldn't resist
check the distances from fixed points would be a starting point
Still none the wiser I am afraid. I'm not a plumber so you will need to explain what you mean. Thanks.
Ok well the flue is located on our gable wall facing next doors wall and I would say that it is less than 2.5 metres from the property boundary. So I assume that it needs to be relocated anyway! Only option is out of the roof...
hmmmmmmmmmm?, i'll have to think about that. :wink:
How far does the OUTER part of the flue stick out from the wall ?
Its almost certainly possible to fit a plume diverter. It probably only needs an elbow or 45° elbow if available.
If its much within 2.5 m from the boundary that should have been considered and discussed with the installer.
It sounds as if its in a narrow passage between houses where the wind speed is accellerated.
Hi
It's difficult to say exactly how far the flue sticks out of the wall as it's quite high up, but I would estimate about 9 or 10 inches, ish.
Agile you are correct, it is located between two houses in a passage. As far as distance to boundary, I'm not sure, but I'm 6 foot and I wouldn't be able to lie down across it.
I'll look into plume diverters, and hopefully this might be a problem solver.
Al
It sounds like a lazy installer!
Its normal to cut the flue off so that there is only about 30-60mm of white outer flue tube protruding.
Had he cut it to that length it would be further from the boundary and possibily would not make such a noise.
Wind is slowed by friction with stationary surfaces and will be slightly less by the wall, particularly if its rough like pebbledash.
To defend the installer here there is only the black vent part on the outside wall no white flue pipe at all. It was fitted well and properly I just need to see if there is a solution to the wind blowing over the end and making a noise. Would a vent end that is finished at an angle help, as the one on at the moment is a straight cut?
You will need the correct manufacturer's plume diverter part.
Possibly a 45° outlet.
