Combi or indirect hot water?
4 Dec 2004
Wiltshire
Hi Guys, long time no speak.
I will be putting in a new upstairs bathroom to replace the existing downstairs in my son's three bed terrace, using the 3rd bedroom, 11' x 8'4".
Plenty of room, and I would like to fit a stud across the short side, effectively making a lobby entrance to the bathroom, and use this smaller area for an airing cupboard. Unfortunately, a plumber has convinced my son that he doesn't need the airing cupboard, and should have a pressurised system fitted. Currently the house has an old combi, which I will replace with a condenser boiler. I would prefer to fit an indirect HW tank, thus providing a good heat store for a linen cupboard, and also due to the maintenance reqirement, and I would prefer not to have a fully pressurised system.
I would welcome any advice and recommendations from the cognoscenti.
Happy Christmas to everyone.
Why not split the difference and fit an unvented cylinder, so you get mains pressure hot and cold and also an airing cupboard.
- as long as your water supply is good enough.
regards
All new boilers now have to be condensing and a stainless steel fully insulated will be alot better with longer warranty then any copper cylinder
sealed heating is alot more efficeint to run , bleed etc,cant see any great issues with maintence and sytem has less chance of corrosion build up
So you would suggest using a radiator to heat the cupboard, or does the pressurised system incliude a hot stainless tank?
I think you're a little confused: A pressurised system is usually the boiler/heating, whether it be a combi or heat only boiler. A "pressurised cylinder" is known as unvented.
Surely if it's your son's house it is his choice as to what is installed.
I certainly am, which is why I posted!
I understand, reasonably well, as I have plumbed two houses:
1. Vented systems
2. Unvented systems, as in my own house, CH & HW running at 1bar off a Viessmann Vitodens 200-W.
But I have not dealt with pressurised (mains hot water pressure) systems, and as I am paying for it, and doing the work, I am reluctant to fit a system which requires annual maintenance (other than the boiler).
Hence my general query as to the advantage of a fully pressurised (mains pressure) hot water system, which appears, from a neighbour's, to require far more equipment, and therefore space to fit. Please also bear in mind that this property will now become a two bed terraced house where storage space is at a premium. I accept that a hot water cylinder also takes up space, but it also serves two useful purposes, IMHO.
Therefore I would welcome hearing the arguments in favour of a 'mains pressure' system for hot and cold water, with all the attendant equipment, installation & maintenance required, as opposed to, what I had intended, a traditional unvented indirect cylinder system, the boiler for which will also supply central heating. (There is currently no make up tank for CH).
Happy Christmas to All
An unvented cylinder should be installed only by a G3 certificated engineer.
As to the system you fit, personal requirements and available space, water etc, are the all important factors
Precisely my concern Mick, and is a good argument in favour of a traditional system.
Chris
