hi, need some help we have fitted a 900 x 450 indirect cylinder in airing cupboard fed from a cold water tank in the loft, this cylinder only supplies hot water to bathroom and kitchen tap it was connected to the gas warm air Janus 3 water heater but was disconnected by previous owner so now the water is heated by the immersion heater element only.
Turned off mains supply, turned off power to immersion heater, drained down cylinder inc tank in loft, undid top vent/ hot water outlet followed by the bottom cold water feed then undid the two coil feed connections removed cylinder, removed immersion heater unit refitted to new cylinder ( a like for like ) refitted into cupboard reconnected all four pipes.
Turned on mains water and checked the cold water tank in loft filled ok, water filled into cylinder checked for leaks ok but no water running from cylinder to taps, cylinder is fully filled as I released the top outlet vent connection and water was present so why does it no flow out of the cylinder to the taps? It is gravity feed so water hot or cold should flow should'nt it?
As I stated the cylinder is not connected to the heating system and is used only for hot water tap supply.
