combi stat
24 Jan 2008
Devon
Hi, can anyone advise what cable to buy to wire a drayton combi stat to a Biasi M96 32S condensing combi.
Thanks in advance.
If you mean you are wiring into the boiler its self, make sure it is heat resistant. I normally use 0.75mm heat resistant (85C)
yes, i'm running the flex from the stat to the boiler.
Theres a mention of two or three wire set-up. Can anyone elaborate?
2 wire is the one. All you are doing is making or breaking the connection that the loop used to make.
It is very low voltage so its safe enough hard to make a mistake . It will either work or it wont.
Manufacturers instructions over rule anything I say that contradicts
