That's near enough what I've got. There's one small snag (in these low flow temperature days)- the option to run flow at a high temperature when the cylinder calls for heat is an installation either/or with the combi section on the Rapid 24 and 32.Look at the Intergas offering.
Fit a 24kw combi as open vented and hook it up fo the cylinder.
Boiler can deliver water to kitchen and utility area, cylinder to washing drawoffs
You can run with a cylinder but the max cylinder temp is then determined by the heating flow temp- not ideal for piping hot water if you run at 55 or 60° to the rads.
It may be possible via Opentherm but I don't know how yet.
