Hi I've got what i thought was a combi but it has no filling loop.
is it possible it is connected to the header tank and through the CH pipes and it refills this way. Its just the pressure is reading at 0 and I was thinking it should be between 1 and 2.
THe place where the booklet says ity should be connected to the cold mains is capped off (looks like factory sealed it so was never intended to be used.
There is a hot water cylinder for the hot water that the CH pipes heat up.
Is this a comnmon setup?
