I have a fairly new fit combi boiler in my house but I am planning to fit solar panels and a woodburning stove with a back boiler.
The panels and stove require a hot water tank that my boiler will not support.
Is there a 'standard way' to mix these two systems?
I was planning on having the two heat sources feeding the hot water system via a motorised valve controlled by a thermostat on the hot water tank. In the event of the tank water being colder than the set temperature then the valve would switch to the combi and visa-versa.
Hopefully this will permit the two systems to feed into my taps and shower.
Does this sound plausible? It is definitely preferable (and cheaper) to ripping out a 2 year old boiler to convert the system to store hot water.
