Hi all,
So i was gifted enough composite decking to replace our aging wooden one.
However, i’ve found that the edge profile where the clips go is different to every other type of composite board that I’ve seen (see pic below).
Most boards have a square edged profile for those black plastic clips. Mine came with metal clips, again that i cannot find online. But with those metals clips you have to install the boards in a set way. These blakc plastic clips allow you the flexibility of starting where you want and simply slotting the board in.
However, if you look closely the bevelled edge of the boards gives a false impression of the gap needed to get the 3.5mm screw in between. The gap between would end up being much wider than would look decent, if that makes sense?
Any ideas what i can do to remedy this please?
